PLOG Actual Times
Phild
Phild
Too Much Forum (686 reputation)Too Much Forum (686 reputation)Too Much Forum (686 reputation)Too Much Forum (686 reputation)Too Much Forum (686 reputation)Too Much Forum (686 reputation)Too Much Forum (686 reputation)Too Much Forum (686 reputation)Too Much Forum (686 reputation)
Posts: 8, Visits: 34
When in navigation mode, the plog is populated with ATA once a waypoint has been reached. I really like that, however, once you exit out of Navigation mode it seems that all of that info is lost.
Is it possible for this information to be retained - as part of the Track Log perhaps - so that you can refer back to it a later time?
Phil
Biggles-EGKB
Biggles-EGKB
Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)
Posts: 51, Visits: 417
I've raised this issue in a previous thread and agree with you that not having access to the info post flight is a real pity.
See
http://www.skydemon.aero/forums/Topic6906.aspx
Biggles -- EGKB
Edited 9/10/2012 9:47:08 PM by Biggles-EGKB
srayne
srayne
Posts: 388, Visits: 8.3K
You can get the time to ech waypoint by loading the log into plan and opening the vertical profile view of the log. Then move your cursor along the profile and the elapsed times can be view in the status bar at the bottom.
I know this isn't exactly what you are asking for but is the nearest that I can find. The take-off and landing times are displayed at the bottom of the profile along with lot of other info about the flight.
Simon
Biggles-EGKB
Biggles-EGKB
Not quite what I had in mind when using modern technological devices.
I think a pen, watch and the paper plog is a safer way to record the info if there is no other facility for getting the data out of SD, post flight.
Biggles -- EGKB
Edited 9/11/2012 10:03:33 PM by Biggles-EGKB
