PLOG Actual Times
http://forums.skydemon.aero/Topic7147.aspx
By Phild - 9/9/2012 10:37:41 PM
Hi
When in navigation mode, the plog is populated with ATA once a waypoint has been reached. I really like that, however, once you exit out of Navigation mode it seems that all of that info is lost.
Is it possible for this information to be retained - as part of the Track Log perhaps - so that you can refer back to it a later time?
Phil
By Biggles-EGKB - 9/11/2012 10:02:16 PM
Not quite what I had in mind when using modern technological devices.
I think a pen, watch and the paper plog is a safer way to record the info if there is no other facility for getting the data out of SD, post flight.
