Visits: 19
Hi, I did not try do something via iTunes, so no help from this side, but this worked:
Look on the forum for topic>aircraft profiles>>How to download and use Aircraft files. Transfer your files to your PC as discribed in the topic (100% working), then on your PC in section AIRCRAFT select the aircraft what you want and SAVE TO CLOUD /one ACFT a time/..., then on your iPad go to>Flight details>>route AIRCRAFT>>>tool>>>>open from cloud, and you should be able to see your ACFTs, select and you are done.
My ipad: An "opened aircraft" is available on my iPad and in flight details I am able to select various aircrafts.
Have a fun,😉 Jaroslav
