Postcode Updates
PB
PB
Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)Too Much Forum (689 reputation)
Posts: 6, Visits: 45
Since the postcode search feature has been added, it seems to sync with my device every time I connect (which takes a while).
Is this correct?
How to proceed?
nje
nje
Posts: 384, Visits: 4.2K
Same here, using 5 inch chinese device
Colin Bond
Colin Bond
Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)
Posts: 63, Visits: 510
Can someone tell me how I can use iTunes to copy the extracted postcodes file from my PC into the SkyDemon folder on my iPad please?
Posts: 593, Visits: 4.9K
Connect your iPad to the computer, then open iTunes. Click on your device on the left hand side, then click the Apps tab. In the lower part of the window, there will be a list of the small handful of apps on your device that support document transfer. One of those will be SkyDemon. Click on it to select it, and you'll then see the SkyDemon 'files' in the window to the right. Drag 'n' drop your postcode file into that window, then hit the Sync button at the bottom.
Colin Bond
Colin Bond
Very many thanks Stevelup, worked a treat.
Colin.
churchy
churchy
Posts: 8, Visits: 39
Does anyone (maybe Tim Dawson could answer) know if the Post Codes database has any use in SD Mobile? On my third party device (AV80R) I have loaded post codes and I have the same problem with the synch taking place every time I synch charts etc as described above, when the post code database probably hasn't changed at all. However, I can't find any Find functionality that makes use of the post code database in the Mobile Skydemon. It seems a bit ironic that you have all the delays on the synchonisation but no benefits once the data is in the unit?
Richard
nje
nje
Using the cheap chinese 5 inch device - with post-codes loaded. go into 'route View' then load a route and you can use ' insert' to put your postcde in and use it as a waypoint.
It is a bit annoying that it always loads the database when syncing, but it only takes seconds so I can live with it for now.
The Mobile software does use the postcode database, for waypoint searching, just as the Plan software does.
