InFlight performance on my PNA Mio C320
aviator
aviator
Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)Too Much Forum (264 reputation)
Posts: 2, Visits: 65
Hi Tim and all,
I just installed v.0.9.7 successfully on my Mio C320 device but it lacks a bit of performance compared to the previous version.
Does it increase performance if InFlight is installed in the flash memory and not on the SD card? Are there any other tips
how to let it run smoother?
Michael Dannemann
PNA: Mio C320 with builtin GPS SiRF Star
PDA: iPAQ hx4700 WM 6.1 with GPS Holux Slimline
SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)
It might be the roads and railways. You can turn them off. In fact there's a bunch of stuff you can do to increase performance. In options if rendering is turned up to high quality you could try reducing it down to the bottom setting, which still looks good but is much faster. Also in the latest version you can turn off coastline rendering which helps a lot and makes no difference to in-land flights.
Cliff172
Cliff172
Too Much Forum (868 reputation)Too Much Forum (868 reputation)Too Much Forum (868 reputation)Too Much Forum (868 reputation)Too Much Forum (868 reputation)Too Much Forum (868 reputation)Too Much Forum (868 reputation)Too Much Forum (868 reputation)Too Much Forum (868 reputation)
Posts: 12, Visits: 28
I am thinking of buying a Mio C320 to try inflight.  Did you find another way to install it?  Or is MioPocket still required?  If so , is it tricky to setup?
Many thanks in advance
Cliff
