Problem with IPAD version following a password reset
ktallent
ktallent
Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)
Posts: 3, Visits: 16
Hi all this is my first post on the forum and is regarding an issue I have just encountered with SD 2.3.3 for IPAD, I registered for the FREE 30 day evaluation and downloaded and installed SD on my IPAD, everything went fine. I proceeded to have a play with all the features and input and save a few routes and configure my aircraft. Then I requested a reset password via the new website and a new notification email was received immediatley, however when I tried to run up SD on my IPAD it failed to start, the startup screen appeared for a couple of seconds and then SD stops with no error mesage. My assumption is the password is stored locally on the IPAD and when SD starts it authenticates over the web and there is now an issue as the passwords do not match but rather than presenting the login screen to enable you to enter your new password it just closes down (or so it would appear). The only way I could find to get access to SD again was to uninstall and install again, the downside to this was I lost all my previous route and setup info that I had input.
Have I missed something (not that I intend on reseting my password that often).
My first impressions are it's great, very intuitive interface and great graphics, the best I have seen on any flight planning and navigation software.
Well done SD team.
I'm afraid the 2.3.3 release had a bug in it, and we've pulled it from the App Store shelves. You'll need to wait a few days for a replacement build to go live, then everything will be back to normal.
