How to display ETA at destination
AnglianAV8R
AnglianAV8R
Posts: 68, Visits: 295
Whilst using mt 5" chinese GPS enroute I can read the ETA at next waypoint. However, I'm sure we should be able to also get ETA at the destination. Is there a setting I need to toggle/adjust to achieve this?
SD and a cheap Chinese satnav = Jobzagoodun.
nje
nje
Posts: 384, Visits: 4.2K
This might not be 100% accurate because I don't have a device with me but you will be able to work it out from here.
Go the the blue skydemon icon, then 'settings' then 'instruments' then check or uncheck your preferences.
srayne
srayne
Posts: 388, Visits: 8.3K
AnglianAV8R (05/05/2012)
Just tap on the ETA-NXT instrument and it toggles between ETA-NXT, ETE-NXT, ETA-END, ETE-END.
AnglianAV8R
AnglianAV8R
Yep, should've known it was that simple. Ta muchly :-)
nje
nje
You learn something every day, I hadn't realised it could be toggled. I knew the height/alt could be, but just noticed on the simulator that you can also toggle the wind instrument. I haven't got my GPS with me so I can't try to see if it's the same on that. Must read the instructions one day.
AnglianAV8R
AnglianAV8R
Instructions? Now that would be a break with tradition !
Although a users guide covering the various questions raised on these forums would be excellent.
srayne
srayne
nje (07/05/2012)
Yup, same on handheld GPS.
nje
nje
Anglianav8r - To be fair to Skydemon, their documentation here http://skydemon.aero/inflight/documentation/
is quite comprehensive and does include the bit about toggling etc, (now I've had a read of it) and is very useful
