Ipad +PC license
sochasz
sochasz
Posts: 16, Visits: 73
Hello.
I have PC license valid until 2 June and tried to use Ipad version during fly. After 30min stop worked and showed me than it's trial version. Should I buy different licence for Ipad version or can I use it until June? How it is?
thanks for answer
Paweł
pink leader
pink leader
Posts: 518, Visits: 2K
I think you need a skydemon mobile licence for the ipad just as you would for a WinCE device. Just the PC licence is no good for flying - it covers planning only.
David
sochasz
sochasz
You're right.
Miichèle
Miich&#232le
Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)Too Much Forum (211 reputation)
Posts: 2, Visits: 2
To all,
I tried Skydemon on my PC Winndows Vista and pn Ipad 3. Evaluation version.
I found the PC version a lot more practical - much easier with the mouse than with the fingers as the finger tips quite quickly have the same temperature as the ipad which means that the screen stops reacting, in which case one must do something to the finger tips to change their temperature, such as blowing on them, very impractical, which slows things down.
I believe that the best solution would be to create the flight on the PC version and transfer to the Ipad to use in flight which brings me to ask you : Are you planning a synchronization feature such as a virtual disk to transfer files between the PC and the Ipad 3 ?
Thanks,
Michèle
If you're having trouble using your iPad in flight, you need to speak to Apple about it. The situation you describe where you're unable to use the touchscreen is very unusual and it sounds like there is something wrong with your device.
You can already share routes from your PC to your iPad, either by emailing them to yourself and opening them from the Mail app or by using iTunes document sharing to manage the SkyDemon Documents folder in any way you like.
dkrizic
dkrizic
Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)
Posts: 2, Visits: 12
a cloud base solution would be much more elegant (and would fit better to the rest of the application), either a service provided by SkyDemon or simply using a directory on Dropbox.
Regards,
Darko
Runways
Runways
Posts: 309, Visits: 1.6K
So far as iPAD is concerned, I believe my SD is working normally, and not in a trial version, following download and installation. I needed to log onto my account initially. There was no license issue. Perhaps, through logging in, SD was able to identify that I am a current subscriber and installed the license for the full version.
Very Newbytheway
DurhamTeaseAirport
Edited 4/24/2012 3:38:33 PM by Runways
