Visits: 293
Hi Tim and crew, when using the SD mobile device I used to press and hold on the aircraft symbol and this would give an accurate position report and made things easy for reporting to ATC, I am now using the iPad and this function does not work, is this intentional and if so would you cosider adding the option to the ipad as i used to find it really useful?
Many thanks
Nigel
