By nwhite007 - 3/28/2012 9:22:22 AM
Hi Tim and crew, when using the SD mobile device I used to press and hold on the aircraft symbol and this would give an accurate position report and made things easy for reporting to ATC, I am now using the iPad and this function does not work, is this intentional and if so would you cosider adding the option to the ipad as i used to find it really useful?
Many thanks
Nigel
By shawkins0 - 5/2/2012 1:11:23 PM
Yes, I would also like scalable data blocks. I think they're too small on the MD. They are bigger on the ancient GPS III pilot which has a smaller screen than the MD.
