Exporting Route from Plan to Inflight
trukkakhan
trukkakhan
Posts: 29, Visits: 57
My mobile device has SkyDemon installed and working and PC has Plan installed. I can save a route from Plan to the Routes folder under the SkyDemon folder on the Storage Card when I put the SD card in the card reader on the PC.When I put the SD card back in the device I can open the route and it shows up.
With the SD card in device and device connected to PC via USB and ActivSync I cannot export to the device. In Plan under tools/preferences/misc I have typed in the path \Storage Card\SkyDemon\Routes - with and without the prefix MyDevice and have gone through all the port settings one by one - I get the message " cannot find SkyDemon check installed properly" etc etc.
The device is a MyGuide 4200 and SkyDemon Inflight works fine otherwise - help !!
Alex
Up and down
Up and down
Posts: 25, Visits: 1.9K
I haven't got the program or device in front of me, but don't you just select 'Sync with Inflight' or something similar, and it just happens? You then open the route from InFlight.
Actually giving it the path "\Storage Card\SkyDemon\Routes" would probably cause it to fail, since it's actually looking for SkyDemon.exe itself, not the routes folder. Try changing the path to just "\Storage Card\" and letting it search by itself. Then, as Up and Down said, just run the sync facility to have it export all your routes.
trukkakhan
trukkakhan
Cheers Tim,
Changing to just Storage Card did the job - thanks
Alex
