SkyDemon Navigation
Ipad2 Skydemon aircraft database
deepflight
deepflight
posted 2/14/2012 12:29:44 PM
Visits: 5
I would like to say thank's to the team to have the opportunity to use skydemon in ipad.
I have a question; if i'm not wrong i can not have a database of different aricraft configuriation so
at the time you need to change the performance items i mean you must work on one aircraft not more.
Hope this will be changed because to have different model is more easy.
Thank you
posted 2/14/2012 2:53:29 PM
Visits: 4.9K
You can have as many different aircraft as you like.
Bring out the Flight Details tab, then touch where it says Default Aircraft. Now press the + button at the top right.
wacits
wacits
posted 2/15/2012 8:01:03 PM
Visits: 43
I am new to the iPad malarkey, how do you download the aircraft profile onto the iPad when using the iPad?
Wayne
posted 2/16/2012 11:03:16 AM
Visits: 4.9K
You can't - you will need to do it manually.
It only takes a couple of minutes though.
Ben
Ben
posted 2/17/2012 2:30:53 PM
Visits: 47
It takes a lot more than a couple of minutes if you have to make big changes to the default values!
posted 2/17/2012 3:53:52 PM
Visits: 4.9K
I've found that tapping -really- fast is quicker than pressing and holding.
helisharing_dot_co_dot_uk
posted 2/21/2012 6:35:12 PM
Visits: 17
From what I can see you can create a lot of things in the aircraft setup/profile, BUT the one really annoying thing I have to seem to set every time I use SD (Light/Planning/iPad etc) is the default altitude and speed, is there a way to have a persistent cookie/ini/setting that can be used across the different products ?
posted 2/22/2012 11:11:26 PM
Visits: 4.9K
The speed default is set by editing the cruise profile of the aircraft definition.
stuartforrest
stuartforrest
posted 2/26/2012 12:44:20 PM
Visits: 108
It takes blooming ages to edit the default values on my 1st generation ipad. Scrolling up and down takes a ridiculous times. I would like to set a few aircraft up. It would be better instead or as well as the scroll things if you could type in a value. That would speed this up dramatically. I think it may be extra slow on an Ipad 1. It did make me wonder if it had been mostly tested on an Ipad2 which are a lot more speedy.
Beech Bonanza A36 Based at Blackpool
G-FOZZ
www.gotoair.com
