Ipad2 Skydemon aircraft database
deepflight
deepflight
Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)
Posts: 1, Visits: 5
I would like to say thank's to the team to have the opportunity to use skydemon in ipad.
I have a question; if i'm not wrong i can not have a database of different aricraft configuriation so
at the time you need to change the performance items i mean you must work on one aircraft not more.
Hope this will be changed because to have different model is more easy.
Thank you
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Hi
You can have as many different aircraft as you like.
Bring out the Flight Details tab, then touch where it says Default Aircraft. Now press the + button at the top right.
wacits
wacits
Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)Too Much Forum (803 reputation)
Posts: 8, Visits: 42
I am new to the iPad malarkey, how do you download the aircraft profile onto the iPad when using the iPad?
Wayne
stevelup
stevelup
Group: Moderators
You can't - you will need to do it manually.
It only takes a couple of minutes though.
Ben
Ben
Posts: 32, Visits: 47
It takes a lot more than a couple of minutes if you have to make big changes to the default values!
stevelup
stevelup
Group: Moderators
Smile
I've found that tapping -really- fast is quicker than pressing and holding.
deepflight - 2/14/2012 12:29:44 PM
stevelup - 2/14/2012 2:53:29 PM
wacits - 2/15/2012 8:01:03 PM
stevelup - 2/16/2012 11:03:16 AM
bsdchapman - 2/17/2012 2:30:53 PM
                         :) I've found that tapping -really- fast is quicker than pressing...
stevelup - 2/17/2012 3:53:52 PM
helisharing_dot_co_dot_uk - 2/21/2012 6:35:12 PM
stevelup - 2/22/2012 11:11:26 PM
stuartforrest - 2/26/2012 12:44:20 PM
