Ipad2 Skydemon aircraft database
http://forums.skydemon.aero/Topic4937.aspx
By deepflight - 2/14/2012 12:29:44 PM
I would like to say thank's to the team to have the opportunity to use skydemon in ipad.
I have a question; if i'm not wrong i can not have a database of different aricraft configuriation so
at the time you need to change the performance items i mean you must work on one aircraft not more.
Hope this will be changed because to have different model is more easy.
Thank you
By stuartforrest - 2/26/2012 12:44:20 PM
It takes blooming ages to edit the default values on my 1st generation ipad. Scrolling up and down takes a ridiculous times. I would like to set a few aircraft up. It would be better instead or as well as the scroll things if you could type in a value. That would speed this up dramatically. I think it may be extra slow on an Ipad 1. It did make me wonder if it had been mostly tested on an Ipad2 which are a lot more speedy.
