SD 2.3 preview serial port crash
iva
iva
Posts: 10, Visits: 26
SD 2.3 preview is crashing when starting navigation mode, the "Start GPS" button in the upper right corner, to be clear.
It happens on Windows XP sp3 32 bit, I'm using SkyDemon on my netbook.
The crash only happens with the real GPS input, the simulator works ok.
This is a regression, it didn't happen with version 2.2.1, that worked fine.
Here's the crash info:
System.NullReferenceException: Object reference not set to an instance of an object.
at Divelements.Aviation.FlightPlanner.Rendering.x5cf3c184e49e0afe.x54b213970b81a42a(Object xe0292b9ed559da7d, GetFollowBoundsEventArgs xfbf34718e704c6bc)
at Divelements.SkyDemon.Mapping.xec68586cbe898f8a.OnGetFollowBounds(GetFollowBoundsEventArgs e)
at Divelements.SkyDemon.Mapping.xec68586cbe898f8a.x3941aff21e021055()
at Divelements.SkyDemon.Mapping.xec68586cbe898f8a.xed48421bb1d76810()
at Divelements.SkyDemon.Mapping.xec68586cbe898f8a.x37450d182ffa6896(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Divelements.SkyDemon.Navigation.x3080cce1274a1680.OnValueChanged(EventArgs e)
at Divelements.SkyDemon.Navigation.x3080cce1274a1680.xa8afddebe03dfe72()
at Divelements.SkyDemon.Navigation.x3080cce1274a1680.x0935201c0c3918e2(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at Divelements.SkyDemon.Navigation.x52ba0270bff5b762.OnValueChanged(EventArgs e)
at Divelements.SkyDemon.Navigation.x61cfd1479e9ac1e9.x67ebd625708f7213()
at Divelements.SkyDemon.Navigation.x61cfd1479e9ac1e9.x14ebd1aedf1a7315()
at Divelements.SkyDemon.Navigation.x61cfd1479e9ac1e9.x4faa1846a9a2a954(Object , EventArgs )
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 2.2.1.30565
Win32 Version:
CodeBase: file:///D:/SkyDemon/SkyDemon.exe
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///D:/SkyDemon/Divelements.SandGrid.DLL
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///D:/SkyDemon/SandDock.DLL
Assembly Version: 1.0.4403.30563
Win32 Version: 1.0.4403.30563
CodeBase: file:///D:/SkyDemon/Divelements.Aviation.DLL
Divelements.Mapping
Assembly Version: 1.0.4403.30562
Win32 Version: 1.0.4403.30562
CodeBase: file:///D:/SkyDemon/Divelements.Mapping.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SandBar
Assembly Version: 1.4.3.1
Win32 Version: 1.4.3.1
CodeBase: file:///D:/SkyDemon/SandBar.DLL
enabled.
For example:
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
Thought I'd check this out & can confirm the same results.
Testing by using GPS input from FSX (HW Virtual Serial port & Fsx2NMEA, credit to col-lucy )
As soon as SD GPS is enabled on the PC, SD crashes with the messages shown by iva
Regards,
Max.
Thanks for this report, we'll get it fixed and post a new beta later today.
