Possible issue with Italy chart
filippo1974
filippo1974
Posts: 12, Visits: 38
Hi All,
I've noticed a probable issue with Italy charts.
I've installed the latest version of SkyDemon Charts for Italy, Austria and Switzerland. I've noticed that Bolzano aerodrome shows two overlapping ATZs with same vertical limits (one is biscuit-shaped, the other is round; the Italian AIP only shows the biscuit-shaped ATZ).
Similarly, the nearby Trento airport appears to have no ATZ in SkyDemon, while the AIP instead shows a round ATZ.
For clarifications, You can refer to Italian AIP, ENR 6.3-5 (Padova VFR chart).
Best regards,
Filippo
Filippo1974
PPL(A) holder - CPL + IR + MEP in progress
Senior specialist in throwing Italian ATS units into panic every weekend.
Rob Hart
Rob Hart
SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)
Posts: 77, Visits: 454
Filippo, you are quite correct and I will amend these soonest. Thanks for bringing these to our attention, and if you see anything else at all that seems out of place I will investigate and correct as soon as possible.
Rob
filippo1974
filippo1974
Hi Rob,
Thank You for the prompt reply.
I'll wait for revised chart updates!
With best regards,
Filippo
Filippo1974
