Missing noise sensitive area near LFMA
dvah
d
Forum Member (26 reputation)Forum Member (26 reputation)Forum Member (26 reputation)Forum Member (26 reputation)Forum Member (26 reputation)Forum Member (26 reputation)Forum Member (26 reputation)Forum Member (26 reputation)Forum Member (26 reputation)
Posts: 4, Visits: 1
Dear team,
The SD chart is missing one sensitive area in the LFMA area called "la Molière" (both on VAC approach and landing charts) which is located in the west of VRP "AR".
All the other noise sensitive zones are present except this one which is surprising.
--> Can you check and consider adding this zone?
Here is attached the extract of the SD chart (missing zone circled in red):
the official VAC and approach charts now below (the zone highlighted in yellow):
Thanks for reporting this, we will investigate.
