Version 4.3.0 Feedback
GalaxyzA11+
G
Too Much Forum (253 reputation)Too Much Forum (253 reputation)Too Much Forum (253 reputation)Too Much Forum (253 reputation)Too Much Forum (253 reputation)Too Much Forum (253 reputation)Too Much Forum (253 reputation)Too Much Forum (253 reputation)Too Much Forum (253 reputation)
Posts: 36, Visits: 2
Tim Dawson - 6/17/2026 9:41:04 AM
The airspace stack colours are based on the chart style you have selected. In the screenshot from the manual, a SkyDemon chart style is selected. If you have selected another one, then your airspace stack colours will be different.
I was slightly wrong about the ordering of airspace items in what's here: it's done by type first, then vertical limits. So controlled airspace will appear first, followed by D/R/P areas, then others. Although we have no objection to changing this if people don't like the way it works, it has been like that for a great many years so we consider it stable.
Your own screenshot is quite messy because you've set your automatic decluttering settings so that lots of high airspace is included. I had to adjust my settings to generate a what's here that has so much information. You might consider adjusting those settings.
I agree with you that the "vertical" is unnecessary; this was always included in the PC version and it made its way to the now-standardised what's here in the latest version. It's likely that we will revert that change.
Hello Tim,
Version 4.3.1 flushes the vertical word, thank you all' 🤗
I think decluttering is not the point.
As you said now, it is not classified from Most to Last important, but by familly and sub-familly.
The first request was not to change that order, but only to sort the data inside a sub-familly.
Familly : Airspace
Sub-familly :  A,B,C,D,E sorted by floor,  higher floor on top, lower floor below of the list.
Sub-familly : R,D,P, Mil sorted by floor from height to low also.
I think it was the first intention at top of the subject.
If I would be alone, I would sort this subs-item all together, including RMZ and TMZ, as a single familly (Airspace) I only mean the items inside the airspace familly. Not the other familly.
In fact, the airspace would be sorted by height, like the graph does.
In think it confusing to read.
And last but not least, you previously wrote that if someone would like to identify one sub through its height, he should use the graph...
But the graph is not longer showing that different aeras ! 😒  Oups....they disapear...!
I.e. when multiple controlled airspace are superimposed , only a single overall zone is despicted in blue on the graphic... ( Containing E, D and CTR without vertical separator) This is not hepling a lot o identify who's who.
Have a nice week !
