Trip Overview: The Use Remaining Fuel doesn't appear.
Daniel Biton
Daniel Biton
Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)Too Much Forum (532 reputation)
Posts: 41, Visits: 439
I have a 220 NM planned route created with 9 legs and 9 landings.
When displaying "Trip Overview", le total "Fuel Burn" indicators shows 45 litrers (a fuel quantity lower than the total quantity filled 60 liters).
For each leg, we the buttons "Go to Flight", "Fuel plan" but no "Use Remaining Fuel" button appears.
Is there a choice to click on to enable this button?
Thanks a lot,
Dan.
Could you contact customer support with this please?
Daniel Biton
Daniel Biton
Thanks a lot, I'll do it.
Dan.
GalaxyzA11+
G
Too Much Forum (272 reputation)Too Much Forum (272 reputation)Too Much Forum (272 reputation)Too Much Forum (272 reputation)Too Much Forum (272 reputation)Too Much Forum (272 reputation)Too Much Forum (272 reputation)Too Much Forum (272 reputation)Too Much Forum (272 reputation)
Posts: 39, Visits: 2
Daniel Biton - 6/15/2026 2:51:41 PM
Dan.
I have the same problem... no remaining fuel :-(
A Trip Overview is available in the Route menu when you have a multi-sector trip planned, allowing
you to see totals for distances, times and fuel. There are also useful tools to help you plan fuel stops.
Tap ‘Fuel Plan’ to see a breakdown of the minimum fuel needed for each sector, as well as an option
to enter the amount of fuel you wish to take. If there’s enough fuel available after the previous leg,
you’ll have an option to ‘Use Remaining Fuel’.
Do you get an answer ?
Daniel Biton
Daniel Biton
Good evening,
i received a quick answer.
The problem comes from the definition of the airplane.
More than one tank and "remaining fuel doesn't work.
Therefore I mofified the definition of my aircraft.
Before, it had two tanks of 30 liters, now, it has only one 60 liters tank.
Then, the "Renaining fuel" button appears back!
Dan.
GalaxyzA11+
G
Daniel Biton - 7/2/2026 8:26:55 AM
Good evening,
Dan.
Thank you, I merge my tanks on one and it works.
Tested yesterday , usefull for long trips !
