Connecting a Dynon SkyView Radio (SV-COM) via Bluetooth to SkyDemon
Michael Hoffmann
Michael Hoffmann
Too Much Forum (395 reputation)Too Much Forum (395 reputation)Too Much Forum (395 reputation)Too Much Forum (395 reputation)Too Much Forum (395 reputation)Too Much Forum (395 reputation)Too Much Forum (395 reputation)Too Much Forum (395 reputation)Too Much Forum (395 reputation)
Posts: 50, Visits: 23
Hi all,
we would like to share a small update from SD-Link that may be interesting for pilots using SkyDemon together with a Dynon SV-COM radio.
We have developed a new Bluetooth Low Energy adapter for Dynon SV-COM radios controlled via a Dynon SV-COM-PANEL.
The adapter allows frequencies selected in SkyDemon to be sent directly to the Dynon SV-COM radio, without manually entering them on the radio panel.
The adapter is installed as a plug-and-play connection between the existing wiring and the SV-COM system.
No separate power supply is required.
We have also uploaded a short video showing the frequency transfer during an actual flight.
More details are available here:
SD-SV-COM
Supported systems include Dynon SV-COM-425, SV-COM-760, SV-COM-T83, SV-COM-T25, SV-COM-X25 and SV-COM-X83, provided they are operated via an SV-COM-PANEL.
Please note: the adapter is intended for experimental use only.
Cheers
Michael
SvenSommer
S
Posts: 1, Visits: 1
Very interesting.
I fly with a Dynon SkyView HDX and an SV-COM-425. Manually entering frequencies is one of the few things I still regularly do in flight.
Does the adapter require any configuration on the SkyView side, or is it really plug-and-play once installed between the SV-COM panel and the radio?
I’d also be interested to hear whether anyone has already flown with it in practice.
