Connecting a Dynon SkyView Radio (SV-COM) via Bluetooth to SkyDemon
http://forums.skydemon.aero/Topic38990.aspx
By Laycom - 5/28/2026 10:14:14 PM
Hi all,
we would like to share a small update from SD-Link that may be interesting for pilots using SkyDemon together with a Dynon SV-COM radio.
We have developed a new Bluetooth Low Energy adapter for Dynon SV-COM radios controlled via a Dynon SV-COM-PANEL.
The adapter allows frequencies selected in SkyDemon to be sent directly to the Dynon SV-COM radio, without manually entering them on the radio panel.
The adapter is installed as a plug-and-play connection between the existing wiring and the SV-COM system.
No separate power supply is required.
We have also uploaded a short video showing the frequency transfer during an actual flight.
More details are available here:
SD-SV-COM
Supported systems include Dynon SV-COM-425, SV-COM-760, SV-COM-T83, SV-COM-T25, SV-COM-X25 and SV-COM-X83, provided they are operated via an SV-COM-PANEL.
Please note: the adapter is intended for experimental use only.
Cheers
Michael
By SvenSommer - 6/8/2026 6:24:28 PM
Very interesting.
I fly with a Dynon SkyView HDX and an SV-COM-425. Manually entering frequencies is one of the few things I still regularly do in flight.
Does the adapter require any configuration on the SkyView side, or is it really plug-and-play once installed between the SV-COM panel and the radio?
I’d also be interested to hear whether anyone has already flown with it in practice.
