GPX Export
Nik
N
Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)
Posts: 16, Visits: 0
I know, via share I can export the GPX file. But only within a complete set (zip).
2 Request:
1. Export of a single file (in my case only the .gpx to save it on a stick and import into EFIS)
2. More important: The <name>-Tag within the file should be customizable. At least containing the same name as the file itself. For all my local flights I have everytime the same name and my EFIS (Kanardia) uses the <name>-Tag and not the filename
For 1.: I use Android (GrapheneOS), probably it is a OS-Problem?
Hope there are some others who like this little daily-use-feature ;-)
It's not really common in consumer apps to have customisable export options. The encouraged way to do it is to ask the operating system to present a Share action with all the file formats that you can produce, which in our case is a few, GPX included, and the operating system presents a list of apps that can handle those files. If there's a file-storage app that can save them, I would hope that it allows selection of individual files for saving.
Given the above, we can't really present an option to customise the <name> field of the GPX. I checked the code, and it looks like we are using the name of the log correctly, e.g. "LFLI Annemasse - LFGA Colmar Houssen" and that seems right to me. I can't think what else would be sensible.
