Import waypoints datas from KMZ file
tomdubois
t
Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)
Posts: 2, Visits: 0
I'm looking forward to import a file (KMZ, KML or whatever) that includes waypoints (in my case water sources for my helicopter job).
I'd like it to act as layer I can select or unselect.
Is there a way to do that?
Thank you.
Tom
You need to first convert your KMZ/KML waypoints to GPX, which is a format actually designed for waypoints. There will be utilities out there to do this. Then you can open your GPX file in SkyDemon and import it as a folder of waypoints, which can be turned on and off easily.
tomdubois
t
Posts: 2, Visits: 0
Tim Dawson - 4/13/2026 8:57:04 AM
Thanks a lot, it worked.
Do you know by any chance if there's a way to customize the whole folder so the waypoints have a specific icon instead of doing it one by one (I have 400+ waypoints).
Not in SkyDemon, no. If you're on a PC you could probably just open the waypoints folder in Notepad and do a find/replace on the symbol type.
