Weight and balance x axis
C401
C401
Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)
Posts: 14, Visits: 84
Can the data for the x axis on the weight and balance envelope graph be changed? I have my club aircraft set up with all the loading points and arms etc but the graph in the aircraft PoH relies on "loaded aircraft moment/1000 (pound-inches)" as opposed to the arm. This means that when I set up a flight (C172 btw) with 2 up and full fuel the graph shows it shows that i would be extremely out of balance, whereas it is actually quite within limits.
Posts: 8.1K, Visits: 9.3K
I'm afraid that for the time being the graph defined in SkyDemon needs to have arm-inches (or cm) along the X axis so some manipulation of the (apparently premultiplied) figures in your POH will be needed.
