By C401 - 8/20/2011 10:14:38 PM
Can the data for the x axis on the weight and balance envelope graph be changed? I have my club aircraft set up with all the loading points and arms etc but the graph in the aircraft PoH relies on "loaded aircraft moment/1000 (pound-inches)" as opposed to the arm. This means that when I set up a flight (C172 btw) with 2 up and full fuel the graph shows it shows that i would be extremely out of balance, whereas it is actually quite within limits.
By Tim Dawson - 8/30/2011 4:24:47 PM
I'm afraid that for the time being the graph defined in SkyDemon needs to have arm-inches (or cm) along the X axis so some manipulation of the (apparently premultiplied) figures in your POH will be needed.
