Add needle pointer to HSI instrument
Posts: 659, Visits: 32K
When using the 'Track Waypoint' feature, the QDM/QDR are given in the Search/Position block at the top of the chart.
It would be nice if the QDM could be replicated with a needle pointer on the HSI instrument (as in an RMI) when this feature is being used.
(A really nice supplementary feature would be the option to enable ADF dip on the needle. This would help when training pilots for the UK the IR and IMC rating in areas where accessible NDBs are thin on the ground).)
I would add that I'm aware that were the second point above be added, one couldn't really use it for serious training in ADF/NDB tracking or procedures, due the SD HSI being based on GPS track and not Mag Heading, but there are certain tasks where it would be useful for demonstration purposes.
I had to double check this one. The bug on the HSI is used when the "track radial" function is activated. It's not a function I normally use, but it adds a line on the chart extending from a waypoint at a specified radial, and when active, the HSI switches into a tracking mode for that waypoint.
If I understand correctly, you'd like the bug to also work when not using track radial, but just when tracking a waypoint? So that it would move around the dial and always point to the waypoint, replacing the normal bug that would appear that reflects to the course to your next planned waypoint?
Tim Dawson - 11/24/2025 10:01:01 AM
That’s correct, Tim. It just replicates the bearings to and from the selected point which are displayed numerically in the search bar with a needle pointer. Something like this (although I posted the wrong image with the needle in the wrong place!):
Edited 11/24/2025 2:58:55 PM by grahamb
Ah, so not replacing the bug but adding a needle?
Indeed. The bug would continue to represent the planned track, and the needle would point to the selected feature.
It's a nice idea. Hopefully others will chime in here.
Yves Dormoy
Y
Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)
Posts: 7, Visits: 2
Tim Dawson - 11/26/2025 10:10:43 AM
I confirm, it's a good thing to show the direction of a selected device, independently of the followed track. Good improvement !
