Enable aerial photography in flight mode
Clemens Gassner
C
Too Much Forum (62 reputation)Too Much Forum (62 reputation)Too Much Forum (62 reputation)Too Much Forum (62 reputation)Too Much Forum (62 reputation)Too Much Forum (62 reputation)Too Much Forum (62 reputation)Too Much Forum (62 reputation)Too Much Forum (62 reputation)
Posts: 9, Visits: 18
Hi there!
There are already so many requests and posts about adding custom georeferenced charts in SD.
It would be great to have the option to add our own charts — maybe we’ll see this feature someday.
But for now, it would be a really nice feature if the "Aerial Photography" layer were also available in flight mode, not just in planning mode.
Is there any chance we might see such a feature?
Posts: 657, Visits: 32K
Clemens Gassner - 10/5/2025 8:05:04 AM
Hi there!
I believe it already is.
- Touch on the chart somewhere to bring up the ‘What’s here’ pop-up
- touch on the relevant feature/lat-long ref
- touch on ‘aerial photography’ at the bottom of the pop-up
If it’s an airport you touch on the chart, you can access Aerial Photography from the info pop-up.
Not ‘one-touch’ but it’s there.
Clemens Gassner
C
Yes and no.
Yes, you can open the aerial photography that way.
But:
- there’s no moving map
- no details such as track, speed, distance, log, etc.
It would be great to have an option — for example, beneath "SD Ground Cover" and "SD Terrain" in the chart style menu — to choose a "Google Maps Hybrid" style.
It's already enabled in flight mode. Easiest way is to open the Mapping menu and choose Aerial Photography. You'll see your aircraft symbol on top of the Apple/Google maps base layer. Helicopter pilots often use this to precisely locate features, for example.
I don't think real enroute navigation using satellite photography is something many people want, so we have no plans to add all the navigation instruments to that screen at present.
Tim Dawson - 10/6/2025 9:41:37 AM
The option doesn’t appear on the Mapping menu when in Simulate mode (v.4.2.0.423, iPadOs 18.7.1).
You're right, it only appears when you're on the ground, and not while you're in flight. We'd certainly look at revisiting that criterion if people want to use it for more scenarios than we originally envisaged.
Clemens Gassner
C
Nice to hear, Tim!
This option would be great for helicopter pilots, especially for specialized operations like aerial photography, power line inspections, pipeline checks or also for sightseeing flights because of the POI's in google/apple maps
If you revisit it, it would also be great to add a moving map — so that you can choose whether the helicopter should be centered or not.
Tim Dawson: I don't think real enroute navigation using satellite photography is something many people want, so we have no plans to add all the navigation instruments to that screen at present.
Regarding all the other “I want a georeferenced map in XY” posts here in the forum, I don’t fully agree with you, Tim. Yes, not all of them want an satellite photography, but i think most of them would be happy...
If users could choose between OSM and satellite photography, I’m pretty sure there would be very high demand.
primeobjective
p
Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)
Posts: 1, Visits: 4
This could also be a useful feature in an emergency. Eg in an engine failure at night/IMC scenario.
