Logs
BobD
BobD
Too Much Forum (570 reputation)Too Much Forum (570 reputation)Too Much Forum (570 reputation)Too Much Forum (570 reputation)Too Much Forum (570 reputation)Too Much Forum (570 reputation)Too Much Forum (570 reputation)Too Much Forum (570 reputation)Too Much Forum (570 reputation)
Posts: 12, Visits: 28
I'm trying to review some Logs from over a year ago, and therefore quite a way down the list. Using a W10 PC, I can choose Logs, then scroll down to the one I want and click on it. Once I have read it, and close it, the Open File box also closes, rather than allowing me to choose another file, so I have to choose Logs again from the menu, and as this starts from the last Log, scroll down again.
No big deal, but it makes reviewing old Logs somewhat tiresome. If closing the last log left the Open File box open, one could just choose the next log in the list.
Great product, would be lost without it.
Are you by any chance going through logs to get flight times etc from them? If so, the Log Summary function compiles your logs into one table that makes it easy to extract such information.
BobD
BobD
Thanks Tim. Actually, I was looking for average speeds over a range of flights to compare performance of a new Prop. I realise I could work it out from the Log Summary, but the Log display  shows me the speed in individual flights.
The point I was making was that conventional operation when a couple of windows are open is that closing the latest one reverts to the previous window, but not in the case I highlighted.
Cheers BobD
Understood, thank you.
KimW
K
Posts: 56, Visits: 0
BobD - 8/22/2025 11:18:41 AM
Cheers BobD
If you have an engine monitor, consider using Savvy Aviation to monitor you data, that include trend reports on average speeds, Max RPM, CHT and other data you collect.
