Ballistic Parachute Recovery System in ATC flight plans
Ibex
I
Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)
Posts: 7, Visits: 77
updated SERA.4005(a) now requires a ballistic parachute recovery system to be included as a remark in section 19 in the ICAO flight plan.  Quote EASA guidance and acceptable means of compliance docs:
GM1 SERA.4005(a)(14) Contents of a flight plan
ED Decision 2024/007/R
BALLISTIC PARACHUTE RECOVERY SYSTEM
The information on ballistic parachute recovery systems may be included in the field for remarks under Item 19 of the ICAO model flight plan, as specified in Appendix 6 ‘COMPLETION OF A FLIGHT PLAN’ to the Annex to Commission Implementing Regulation (EU) No 923/2012.
[applicable from 1 May 2025 – ED Decision 2024/007/R]
I have not found a way to include this with the aircraft profile, to get it automatically added when selecting an aircraft equipped with such system. Ideally we would get a check box similar to the avionics equipment options somewhere in the emergency equipment section of the aircraft profile which then triggers the remark to be added in section 19.
Thanks for your kind consideration.
-- Ibex
Edited 8/20/2025 11:04:11 AM by Ibex
Posts: 659, Visits: 32K
Ibex - 8/20/2025 9:19:13 AM
-- Ibex
Irrespective of the merit of your suggestion, or indeed the wisdom of including a remark that a BRS system is fitted, SERA 4005 does not ‘require’ it.
The word used is ‘may’, not ‘shall’ or ‘must’, and it appears only in Guidance Material, which is just that - guidance and not binding.
Ibex
I
grahamb - 8/20/2025 6:45:11 PM
The guidance material quoted above is indeed pretty vague on how to include the information on BRS in a flight plan and only suggests how you may do so, however SERA.4005(a) leaves little to no room for interpretation:
SERA.4005 Contents of a flight plan
Regulation (EU) 2024/1111
(a) A flight plan shall include all information considered relevant by the competent authority as regards the following:
(1) aircraft identification;
(14) emergency and survival equipment, including ballistic parachute recovery system;
(15) other information.
Depending which AIS unit you work with I've already had flight plans rejected lacking the information on BRS installed when it was obvious because of the type of aircraft.
-- Ibex
Ibex - 8/21/2025 8:23:57 AM
-- Ibex
Thanks for that - somehow I missed the update to include a BRS in the primary rule. Sad
Felix
F
Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)
Posts: 1, Visits: 0
Hi, I would also appreciate such an update to Skydemon, that I could permantly specify defaults for the regular Remark section and the Survival remarks.
For the new SERA requirement for the BRS, at least German AIS portal for flight plan filing has recently updated their interface to provide a checkbox for availability of a BRS. This leads to a field 19 entry of text "N/BALLISTIC PARACHUTE RECOVERY SYSTEM". I would love to see this configurable in the survival equipment configuration of the aircraft configuration.
Plus, I would love to add the same string for every flight in the field 18 like "RMK/WEB BROWSER LIVE TRACKING xxx.ADL.FLIGHTS" as the manufacturer of our Iridium satellite receiver suggests to add this data for SAR purposes. It provides satellite location via data link and never changes by flight. So configuring this as part of the aircraft configuration would be highly appreciable.
ghost48
g
Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)
Posts: 4, Visits: 4
@Tim Dawson
Are you planning to include this option?
How can I manually add this kind of information to field 19 using SkyDemon? Where would be the in the process of filling out the flightplan in SkyDemon?
Germany and Austria is now mandatory to BRS to your flighplan.
I imagine we will add a checkbox for this, yes. I don't know when though.
ghost48 - 3/18/2026 8:09:22 AM
On the flight plan pop-up screen, toggle the 'Show Full Form'  on, and press 'Continue'. This will display all the flight plan fields. Add the necessary information after a comma  at the end of the 'Extra Information' field which will already contain some information (this is Field 19).
This is coming in the next version.
