Editing my existing aircraft, post code lookup and Pilot Log
Posts: 393, Visits: 2.6K
1. I have had my aircraft set up now ever since subscribing to SD (quite a few years).
Using PC Plan (latest version) I went to edit the default cruise level within my aircraft setup and I saved my changes.
I then planned a new route.
When I went to print the Pilot Log it kept showing the details for the old default cruise level (1750 ft vice 2500 ft AMSL).
I checked my aircraft details again and it correctly showed 2500 ft.
Tried again, but the same issue with the Pilot log.
I had to make a duplicate "aircraft" (then rename it) before the new default cruise level correctly showed in the Pilot log.
Is this expected or an anomaly?
2. I wanted to plan/navigate to a particular point with reference to a post code.
When I went to load the post code file, PC Plan reported "File not found"..
3. When I print the Pilot log, the log's aircraft identifier ("reg" and "type") is different from the aircraft file "name" I selected for planning the flight. Is this correct? If so, how do I know that the log reflects the correct aircraft details etc. for the aircraft that I selected for planning purposes?
Could you contact customer support with this enquiry please? I'm not really the right person for this one.
