FIS (SIV) COTENTIN
julien
j
Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)
Posts: 12, Visits: 0
I may notice some discrepancies in the Normandie area for some FIS information (see the attached screenshot with the yellow marks):
-name, boundary and frequency : FIS COTENTIN part A RENNES instead of FIS RENNES, boundary goes until the yellow arrow (instead of the boundary between BREST FIR and PARIS FIR), missing frequency 120.350,
- name : FIS COTENTIN part B RENNES instead of FIS RENNES,
- name and frequency: FIS COTENTIN part C RENNES instead of FIS RENNES (FL065-FL115), frequency 120.350 instead of 134.200,
- name: FIS RENNES south part B RENNES instead of FIS RENNES (SFC-FL065),
- name : FIS RENNES north instead of FIS RENNES
The map extract is the last map SIA FRANCE North 1-1000000.
I didn't check other FIS RENNES parts but it could be necessary.
Thank you
When you say "the last map", are you aware that a great many SIV areas changed last Thursday, on 17th April? I want to make sure you are comparing with a map that has actually been updated.
julien
j
Tim Dawson - 4/22/2025 9:16:01 AM
Yes, I compared  with the new map edition, dated 17th April (I should have been more precise for the reference!). You can see also the SIV area overview on the AIP AD 2 SIV 01 dated 17th April (for instance for the N°82 which is related to the FIS COTENTIN part A RENNES as mentioned in my previous post). As you mentioned, I assume there are also many other SIV areas updates.
Thank you,
julien
j
julien - 4/23/2025 11:59:38 AM
Thank you,
I forgot to mention that it not an update with the edition of 17th April, the SIV area and information were already as presented before the new edition of the 17th April (see previous SIV map in attachment).
AD 2 SIV 01.pdf (4.9K views, 257.00 KB)
Thanks, I will pass this along.
My colleague informs me that a new chart has been released, could you check it and confirm whether the issue you were seeing has been resolved?
