Zones de Sensibilité Majeure (ZSM)
Aint1
A
Posts: 2, Visits: 0
France has recently implemented "major sensitive zones" to protect raptors in mountainous regions.
Theses zones are depicted in pdf files and a kml file is downloadable on this webpage :
Would it be possible to have these areas appear in the Skydemon map?
Best regards
Antoine des Courtis
jffuchs
j
Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)
Posts: 6, Visits: 30
The glider pilot community from www.planeur.net, with the support of the Federation, maintains a French OpenAir file that includes ZSM (Zones de Sensibilité Majeure - Zones of Major Sensitivity)
Best regards,
Frederic
BernardBig
B
Posts: 2, Visits: 0
Hello Antoine,
having the same need, I decided to write a script to convert the .kml file to .airspace format compatible with SkyDemon
You can download the current version here
Next version scheduled for May 6th
Hope it helps
Edited 4/28/2025 9:53:32 PM by BernardBig
jmservat
j
Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)
Posts: 1, Visits: 0
Just to confirm the need.
I have tried converting the French ZSM xml file to kms or guppy but SkyDemon would not load them.
Could the SkyDemon team propose a solution?
There are many bird sensitivity zones and it is very difficult to navigate without having them in our favourite navigation package.
Other pilots are able to load them in SDVFR.
Thank you
Jean-Marc
Where are these referenced in AIP France please?
pgroell
pgroell
Posts: 106, Visits: 18K
Tim Dawson - 5/7/2026 11:35:04 AM
I don't think they are referenced in the AIP, they are only known via this page : https://www.stac.aviation-civile.gouv.fr/fr/zsm and this file for whole France : https://www.stac.aviation-civile.gouv.fr/sites/default/files/france.kml#
The status changes every month and they are activated or deactivated depending on the status of the birds (nesting or not, presence or not of fledglings).
So there are not really official aeronautical data, and have no aeronautical significance, but pilots stay away from them anyway?
pgroell
pgroell
Tim Dawson - 5/7/2026 1:34:13 PM
As much as possible, pilots should fly around the ZSM.
If flying around is impossible, overflight is permitted at a minimum off 1000 m AGL above the highest point of the area.
GalaxyzA11+
G
Too Much Forum (187 reputation)Too Much Forum (187 reputation)Too Much Forum (187 reputation)Too Much Forum (187 reputation)Too Much Forum (187 reputation)Too Much Forum (187 reputation)Too Much Forum (187 reputation)Too Much Forum (187 reputation)Too Much Forum (187 reputation)
Posts: 36, Visits: 2
pgroell - 5/7/2026 4:02:15 PM
Knowing a bit about that, once an aera is declared, it will stay "declared" for the next 10 years (!) even if no bird has been observed since the past 9 years.... This means nearly all french Alps and Pyrénées will be covered with this aeras.
Adding to that, they have no aeronautical value, but you may go to jail because a of a law that claim that if you disturb these birds in any way (even while walking around) you may be prosecuted.
So far, our judges are a bit busy, and if dont over fly this aeras each day, they will probably not prosecuted you.
At the opposite side, if you turn around a nest take pictures you may have a problem... Even with a mountain bike.
Anyone go mountaineering (fly) will probably know about that. (At least now) 😉
Adam Erchegyi
Adam Erchegyi
Posts: 123, Visits: 3.5K
GalaxyzA11+ - 6/9/2026 7:32:38 PM
you may go to jail
sounds like an overstatement Smile
