Active (by NOTAM) "Temporary Restricted Area" not permanently shown on map
Active (by NOTAM) "Temporary Restricted Area" not permanently shown on...
Hello Christian,
EDR164 is night-only airspace, so you won't see it on your map at all unless you switch on airspace that's only active at night (in your Mapping menu). Once you've switched it on, you'll see it has an orange border because of the NOTAM activating it. Please confirm.
knaumann
k
Too Much Forum (499 reputation)Too Much Forum (499 reputation)Too Much Forum (499 reputation)Too Much Forum (499 reputation)Too Much Forum (499 reputation)Too Much Forum (499 reputation)Too Much Forum (499 reputation)Too Much Forum (499 reputation)Too Much Forum (499 reputation)
Posts: 28, Visits: 35
Just to confirm. Today and until tomorrow (28.05.2025 - 29.05.2025) the ED-R Humboldt is active again:
https://www.daec.de/media/files/Dateien/Fachbereiche/Luftraum_und_Flugsicherheit/NfL_2025-1-3498_ED-R_Humboldt.pdf
SkyDemon is showing the airspace of the ED-R as expected. Thank you again for solving the problem.
cda
c
Posts: 3, Visits: 0
Tim Dawson - 3/18/2025 4:08:21 PM
Hello Christian,
Hello Tim,
thanks for the explanation, I wasn’t aware of that menu option to switch on the night-only airspaces.
Now the restricted areas are displayed correctly.
Would it be possible to have these restricted areas shown automatically during planning or flight if it’s a night flight?
That's a nice idea, but beyond scope at the moment. The chief argument against it is that various definitions of night are available, in terms of exact timings.
knaumann
k
here is an additional RA(T) from today morning which is not permanently shown on the moving map. The flight information service confirms, that the RA(T) Bueckeburg is active. Please check.
RA(T) Bueckeburg
Only visible after clicking on "Show on map"
Video: https://youtube.com/shorts/RoPVacjYg-M
Thank you in advance.
Thanks. I will write to DFS to determine why that restricted area was not notified via the VFR AIP.
Update: you were misinformed. We already have this area. Please refer to VFR SUP 30/25. The area is not yet showing on our charts because its activity times are 25 June to 28 June. If you plan a flight for 25 June you'll see it appear.
knaumann
k
Hi Tim, thank you for investigating.
I had now discussion with the pilot who flew today and was informing me via short message.
He told me the same now. He saw this RA(T) with activation time from 12 June 2025 til 28 June 2025. But there was a misunderstanding. FIS told him, that the NOTAM is active, but the RA(T) is not at the moment.
So thank you for clarification and that it works as it should.
