Land here (but we don't refuel)
Daniel Biton
Daniel Biton
Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)
Posts: 42, Visits: 441
Good evening,
I tried to look for answers scrolling the forum, but I have found no answer.
When printing each pilot log of a 4 route leg flight, I discovered the fuel level was reset after each landing.
This is not a crucial issue, I don't print the remaining fuel column in this case and everything is ok.
Did someone found a work around?
Thanks a lot.
Dan.
Posts: 663, Visits: 32K
Daniel Biton - 9/6/2024 6:13:12 PM
Good evening,
Thanks a lot.
Dan.
I think the basis for this is that SD doesn't know if, where, and by how much you would refuel, so leaves it to the user to specify it.
The way to deal with it is to adjust the fuel on board at the start of each leg to what you think it will be, based on planned fuel burnt on prior legs.
Edited 9/7/2024 12:48:01 PM by grahamb
Daniel Biton
Daniel Biton
Thanks for your answer.
I fact, I was doing what you describe.  After a totol of 3 hours plus landing and take off, it is just time to have a drink, for us and the Zenair.
Flying, for us is not mandatory, it has to be a pleasure.
Dan.
