High resolution terrain, how to enable.
Wire
W
Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)Too Much Forum (325 reputation)
Posts: 19, Visits: 46
Using version 3.16.15.0 on Win10 PC.
I don't know if I have "high resolution terrain" enabled.
I have clicked "Enable high resolution terrain" under  "Terrain and surface features"  but this lake still looks low res.
Something else I must do or download?
High resolution terrain refers to the resolution of the terrain elevation data, not the geospatial data (coastlines and lakes etc). What zoom scale is that?
Wire
W
Tim Dawson - 5/29/2024 8:35:49 AM
Zoom scale is 55k.
Are there any options for geospatial data?
No. 55k is quite a large-scale map; it would help if you could explain the scenario in which you're doing enroute flying at that scale, and therefore would benefit from increased geospatial detail.
Wire
W
Tim Dawson - 6/6/2024 9:35:07 AM
In this example there is a narrow uncontrolled passage between restricted area R112 to the west and ESSB CTR to the east.
I would like to pick some terrain reference as an aiming point, but in this case the map is to coarse to show anything meaningful.
Not a big deal, just wanted to make sure I had Skydemon configured to its full potential..
Thanks. If you open the Mapping menu (bottom right) you should see an option to switch to aerial photography. That will show you the two pieces of airspace on top of satellite imagery. Does that help you achieve what you wanted?
Wire
W
Tim Dawson - 6/7/2024 8:47:21 AM
Thats it!
The CTR is still shown, but I lost the graphic for the restricted area?
I may have been wrong about all airspace being shown in that window. Could you contact customer support about this? They will know the answer.
