Popup box class A
Cole Burner
C
Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)Junior Member (23 reputation)
Posts: 2, Visits: 0
Why does the cross section show Class "A 4500" in one pop up box and not the other?
PC version not tablet
Posts: 659, Visits: 32K
I don’t know the reason, but it does the same in that area on a phone in landscape mode. It seems to be related to the surface elevation at a particular point.
Cole Burner
C
Posts: 2, Visits: 0
I thought that might be the case, but it does it elswhere too (eg just North of Stoke-on-Trent) inside or outside of the AIAA where the ground is the same elevation. Beats me!
Yes, this seems to be to do with the terrain elevation. The visual airspace stack in What's Here starts (altitude-wise) just below the terrain elevation, so you see a certain amount of vertical distance above that.
