Visits: 261
Edited the Default Aircraft but still looks like the original default data are hard wired. I edited Default Aircraft with 4200, 80kts IAS 50L fuel - deleted the 2400RPM, 108KT IAS profile. Restarted SD checked Aircraft Library - Default Aircraft listed and set up as edited. Created routed manually then Checked Flight details as well as Route Print - the orginal Default Aircraft data 2400RPM, 108KT IAS with 100L fuel on board is still being accessed by the system.
