'Fuel on board figure' problem on printout
http://forums.skydemon.aero/Topic3668.aspx
By Robby - 7/23/2011 3:12:18 PM
Hi Tim
Beta version - When I entered a  new route from scratch the printout showed double the fuel on board figure than the airctaft has. I have one aircraft which is set up with 50L. The printout showed 100L
The way I set up the route was
Run Skydemon - using the map select start airfield, then end airfield (route created) - Select Route - Print - Fuel on board = 100L (rather than 50).
I then selected Setup - Aircraft - Selected the only aircraft on the list - Use this aircraft - Route - Print = 50L.
Robby
By Tim Dawson - 7/28/2011 5:42:18 PM
Thanks for pointing out this bug in the beta; it has been fixed.
