inflight V1.1
Max_UK
Max_UK
Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)
Posts: 66, Visits: 2.9K
Tony, Are you still getting this error?:
"On the GPS I have gone into settings then into Navigation Path and set the Navigation Path as "\SDMMC\SkyDemon\SkyDemon.exe". When I then go to the main screen of the GPS and press Navigation I get "Please set Navigation Path"."
If you are it means that you haven't "saved" your Navigation Path by tapping the disc icon at the top before exiting.
If it was a .net problem, SkyDemon.exe will at least try to run & then throw up an error message.
I've also discovered that on my unit, I have to put it into "Sleep" mode, after exiting SKD, to save any registration changes. GPS uses Com1 & 38400 baud works well.
If you are still stuck, send me a PM & I'll point you to a menu to download, which might make things easier.Tongue
I can also confirm that Tim has isolated the problem I was having, & now SkyDemon works on both my Satnavs.
Regards,
Max.
