inflight V1.1
http://forums.skydemon.aero/Topic366.aspx
By Steve - 2/3/2010 8:59:47 AM
Guys,
After having installed the new version of inflight on my windows mobile device, which took a lot more effort then before, just copying a .cab file over to the device was easier, now I have to use the SD Card option as I don't use activesync. I have installed the new version of the inflight, it runs very well, but doesn't install itself in the start menu, so I have had to do that manually, again I didn't need to do that before.
My main issues is that no matter what I try the software says it is an evaluation version, I have copied the license file over to the device, un-installed and then re-installed etc. (also downloaded a new license file, for plan and inflight, plan is working fine).
Can you help me with this please ?
Also, is it possible to have the single .cab file download option available again for copying and pasting to the windows mobile devices ?
Many thanks, Steve
By Max_UK - 2/8/2010 6:58:53 PM
Tony, Are you still getting this error?:
"On the GPS I have gone into settings then into Navigation Path and set the Navigation Path as "\SDMMC\SkyDemon\SkyDemon.exe". When I then go to the main screen of the GPS and press Navigation I get "Please set Navigation Path"."
If you are it means that you haven't "saved" your Navigation Path by tapping the disc icon at the top before exiting.
If it was a .net problem, SkyDemon.exe will at least try to run & then throw up an error message.
I've also discovered that on my unit, I have to put it into "Sleep" mode, after exiting SKD, to save any registration changes. GPS uses Com1 & 38400 baud works well.
If you are still stuck, send me a PM & I'll point you to a menu to download, which might make things easier.Tongue
I can also confirm that Tim has isolated the problem I was having, & now SkyDemon works on both my Satnavs.
Regards,
Max.
