Login Security
Don Bannister
D
Posts: 2, Visits: 3
When logging in recently to the SkyDemon Program on my Windows (10) PC, the Anti-Virus software came up with a somewhat surprising message. It said "An attempt to send your password unencrypted was about to occur on data.skydemon.aero". I wouldn't have been aware of this otherwise and, whilst not a total disaster, I would wonder if it might be better to be a bit more secure. I assume it means that the connection was not secured with SSL, but don't know for sure. Any thoughts ?
SkyDemon Team (701K reputation)SkyDemon Team (701K reputation)SkyDemon Team (701K reputation)SkyDemon Team (701K reputation)SkyDemon Team (701K reputation)SkyDemon Team (701K reputation)SkyDemon Team (701K reputation)SkyDemon Team (701K reputation)SkyDemon Team (701K reputation)
Unless you're using a very old version of SkyDemon, all communications with our server are secure. Even the older versions hashed your password before sending, so the message you saw is simply incorrect.
Don Bannister
D
Posts: 2, Visits: 3
Tim Dawson - 7/31/2023 9:13:06 AM
Thanks Tim.
You were right - I was using a pretty old version. I mostly use SkyDemon on a tablet, where I am used to it telling me when there are updates. This didn't seem to happen with the Windows Desktop version I had.
But the warning message was correct. Although the password was hashed, it and the username were sent in the clear in an http POST, so the anti-virus was pretty much right.
A useful exercise, nevertheless, as I am now up to date with a more secure version, and know that I need to manually check for updates !
Cheers, Don
Edited 8/1/2023 4:32:14 PM by Don Bannister
It's worth noting that all recent versions of the desktop software also check for updates and prompt for upgrade when they are discovered.
