Safesky shared traffic display in SD in a white color icons only
Reinhold
R
Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)Forum Member (29 reputation)
Posts: 4, Visits: 55
I use the collision warning app Safesky and have the traffic displayed in SD via GLD90.
So far I am very satisfied with the function of this setup.
Only a little bothers me that the displayed traffic in SD portrays the symbols in white only.
The outer contour of these aircraft symbols are only shown in a thin line.
If it is possible in SD to represent the transmitted traffic in a signal color, for example, orange or red.
regards
Reinhold
Traffic icons turn yellow then red if they present a proximity threat. Otherwise, on the map, they are designed not to clutter it.
The traffic radar instrument in the bottom right (or full screen, if you're using a phone) is designed to be the primary place to glance to see other traffic around you. Have you tried using that?
