IPad air 3 overheat? AT-1 loosing WLAN connection - Android better ?
Joachim Gothe
Joachim Gothe
Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)
Posts: 19, Visits: 58
I have an IPad air 3 in a RAM Mount. On warm days the IPad is getting hot but it don't shut down. It loose WLAN connection to the AT-1 collision warner. Sometimes it reconnects, sometimes not.
Plane is a VAN's RV6 and the IPad is in direct Sunlight.
I am looking for an alternative (Android?) or an other sollution for the Problem. Is it possible to clock down the IPad ?
Achim
Edited 7/12/2022 10:30:18 PM by Joachim Gothe
Joachim Gothe
Joachim Gothe
Nobody has an answer ?? :-(
Does anyone have experience with the XNAUT iPad mount with fans?
Achim
AerialRob
AerialRob
Too Much Forum (841 reputation)Too Much Forum (841 reputation)Too Much Forum (841 reputation)Too Much Forum (841 reputation)Too Much Forum (841 reputation)Too Much Forum (841 reputation)Too Much Forum (841 reputation)Too Much Forum (841 reputation)Too Much Forum (841 reputation)
Posts: 15, Visits: 7
Joachim Gothe - 7/31/2022 2:25:23 PM
Achim
If you have fresh air vents try and position iPad to receive blast of air to rear surface .
It works for me using an iphone6 .
Gerhard66
G
Posts: 175, Visits: 358
I had a similar issue with my old iPad mini 3.
At direct sunlight, the automatic brightness adjustment turned the display to maximum brightness which led to overheating. I reduced the brightness manually and the iPad cooled down significantly.
Roadrunner99
R
Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)
Posts: 7, Visits: 1
Hi there, I have issues with my ipad pro overheating in use in direct sunlight in normal applications other than SD, shade the device or provide cooling air.
