Definition for aircraft was different to the one in the library
Simon Harrison
S
Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)
Posts: 1, Visits: 0
Win 11
SD - 3.16.3.0
I have updated the definition for an aircraft and then open a previously saved route that uses this aircraft. SD tells me that the definition has changed and it will use the one in the library. So far so good. I then make some changes to the route and re-save it. However, when I re-open it again in the future, without modifying the aircraft definition, it again tells me that aircraft definition has changed.
Q. How can you get a route to recognise and adopt the aircraft definition that is in the library so that you don't get the warning message each time you open the route?
Gerhard66
G
Posts: 168, Visits: 355
Same issue here. Over the years I got used to this old bug and was too lazy to start a discussion here ;-)
iPad mini 5
iOS 15.4.1
SD 3.16.3
Jyleuleu
J
Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)
Posts: 4, Visits: 5
SD 3.16.3
IOS 15.5
Windows 10
I don’t have this issue.
When SD tells me that it will use the aircraft definition of the library, I just click ´OK’ and save the route without changing anything.
When I reopen the route, SD loads the new aircraft définition and don’t warn me anymore.
Rgds
JL
