SD and SkyEcho connection on Android
ThePhantom79
T
Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)
Posts: 14, Visits: 28
I am using SK and Skyecho on my android device (8inch tablet) since 2 years, and I like it a lot.
My android device has also mobile data available, but unfortunately, SD <-> SkyEcho connection does not work 100%, ig mobile data is switched on.
How it is, on my devices (tablet and phone):
Mobile data off: SD and SkyEcho work great, as well traffic visualisation as configuration of skydemon from skyecho menu (thats important, as I switch often the plane, and so I dont haver to enter hex code each time - its done by skydemon!). Live weather / notam data are unfortunately NOT available, due to no internet connection.
Mobile data on: SD and Skyecho connction work basicly, means - traffic visualisation works (so the main functionality is given), but configuration is not availabe (If I click in navigation mode in SD to Sky Echo Configuration, SD cant find my Device). But - as said - traffic information are recevied - so a basic connection seems to be there. Also on browser, the IP of the device is not reachable. But of course, live weather is available,
I think, this is not a SD issue (but not sure), but maybe someone else has this issue and found a workaround?
Adam Erchegyi
Adam Erchegyi
Posts: 100, Visits: 2.3K
ThePhantom79 - 5/6/2022 1:44:05 PM
I'm not sure if SkyEcho has that capability, but to my Stratux I connect via WiFi Direct, solves this problem.
If you need to stick with regular WiFi comnection, you could use the Speedify app.
