Tracking Training Flights
Han3081983
H
Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)
Posts: 5, Visits: 0
Gerhard66 - 4/25/2022 6:15:40 PM
When in flight, did you see the moving map display working correctly?
I actually didn’t check. Was to busy practicing stalls. But I will check next time
mrusk
mrusk
Too Much Forum (380 reputation)Too Much Forum (380 reputation)Too Much Forum (380 reputation)Too Much Forum (380 reputation)Too Much Forum (380 reputation)Too Much Forum (380 reputation)Too Much Forum (380 reputation)Too Much Forum (380 reputation)Too Much Forum (380 reputation)
Posts: 6, Visits: 1
You must not click on "stop navigation" but on "back to planning mode" at the bottom. Otherwise your log data is discarded.
Posts: 384, Visits: 2.6K
If it helps, after planning my flight, I simply click on "Fly".
I don't bother with logging any "engine start" or "off blocks" time.
When I land again I simply shut down SD.
All my flights are logged correctly.
Tony
efrenken
efrenken
Posts: 265, Visits: 3.5K
mrusk - 4/27/2022 11:38:39 AM
It doesn’t matter how you end navigation mode, Either way, “stop navigation” or “back to planning mode”, log data are saved.
