Special Charakters in Name of Pilot
publicom
p
Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)
Posts: 40, Visits: 116
the name of the Pilot, thats filed in a flightplan seems to be the Name that is used in the SD Account. If this name has special Charakters, it won't be accepted, for the flightplan. Also there will be no error message but one can just not press „next“ and has to figure out why.
Is it possible to change the Pilots default Name for flightplans only?
Also it would be good, it was possible to file another Phone Number and also an option to append a default mail adress.
Posts: 661, Visits: 32K
publicom - 4/16/2022 3:03:48 PM
You can edit the pilot’s name in the first FPL pop-up. Once you’ve changed it, it is generally persistent.
Also, you can display the remaining FPL details by toggling on the ‘Show Full Form’ option. This will allow you to edit the RMK/ to add in an extra phone number and/or email.
publicom
p
grahamb - 4/16/2022 4:09:43 PM
Thank You. Meanwhile I found out, that it is possible to change the default Name and Phone Number in the PC Version. I don't know, why it wasnt't transfered to the App.
Also it was great, if the mail adress could be set so it would always be added as RMK/.
The app prompts for the pilot name and telephone number every time you go to file a flightplan.
