SkyDemon flight plan with Skyview autopilot
MarkG
M
Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)
Posts: 1, Visits: 0
Is any one familiar with setting up the Dynon Skyview autopilot to run the Skydemon flight plan ?
If so I would be interested in their set up procedure in Skyview to make this happen.
I am familiar with getting the fight plan to Skyview,  but from  there on unsure
ie - which mode is required simplified or expert ? etc.
Any help from someone who uses these systems would be appreciated
Mark
doychinov87
d
Too Much Forum (221 reputation)Too Much Forum (221 reputation)Too Much Forum (221 reputation)Too Much Forum (221 reputation)Too Much Forum (221 reputation)Too Much Forum (221 reputation)Too Much Forum (221 reputation)Too Much Forum (221 reputation)Too Much Forum (221 reputation)
Posts: 6, Visits: 0
Well, you share what you have planned to Skyview via a Dynon wi-fi adapter and start using your autopilot.
No setup needed.
So in this case,you go to expert mode, hit FD and make Skyview on NAV.
I sometimes keep it simple because they often change my plans so I have to change in the SD, then share back to SV. So in most of the time I use the wi-fi adapter so I have the SV gps in use and only look at the beautiful map in SD. From the LOG I use hdg and alt I planned and just turn the knobs. We make turns in 10+ minutes so there’s not a problem.
Edited 5/3/2022 4:17:55 AM by doychinov87
