By doychinov87 - 5/3/2022 4:06:18 AM
Hello, Well, you share what you have planned to Skyview via a Dynon wi-fi adapter and start using your autopilot. No setup needed. So in this case,you go to expert mode, hit FD and make Skyview on NAV. I sometimes keep it simple because they often change my plans so I have to change in the SD, then share back to SV. So in most of the time I use the wi-fi adapter so I have the SV gps in use and only look at the beautiful map in SD. From the LOG I use hdg and alt I planned and just turn the knobs. We make turns in 10+ minutes so there’s not a problem.
