Touch and Go Functionality
Andrew
A
Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)
Posts: 28, Visits: 88
Having flown a couple of flights recently with a T&G at various fields, it would have helped a lot to have the ability to add a Touch & Go into a flightplan.  Looking through the forum a number of workarounds exist - either "Land Here", but then you effectively have 2 flights which are not well stitched together - separate PLOGS and I assume separate Flightplans; alternatively manually add circuit-waypoints to the T&G field which again is very much a workaround.
I'm sure there's loads of complexity in including this into the flightplan, but would be very useful and make the flight planning process a great deal slicker.
Cheers
Andrew
